MP 1.6.1: Cannot delete on SMB.
tenpaMk2
Post by tenpaMk2 »
XnView: MP 1.6.1 - 64 bit
OS: Mac - 64bit
I cannot delete file on SMB directory.
When I try to delete it, confirmation window is pop up. the message is the below.
> Are you sure to delete these 1 item(s)?
Then, I select Yes. But, the file is remain.
This problem is occur only in SMB directory (ex: Synology NAS).
I can delete images in non-SMB directory.
1. Delete file.
Actual behaviour (bug):
The images still remained after deleting in SMB directory.
:bug:
Expected behaviour:
The images are deleted after deleting in SMB directory.
Thank you developers❗
tenpaMk2
Re: MP 1.6.1: Cannot delete on SMB.
Post by tenpaMk2 »
I have done more tests.
  • MP 1.5.5: Can delete
  • MP 1.6.0: Cannot delete
  • MP 1.6.1: Cannot delete
So, I think there is a bug in change of 1.6.0.
tenpaMk2
Post by tenpaMk2 »
Thank you for your quick fix❗
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
