Autodetect pixel ratio
yacomi9014
Post by yacomi9014 »
XnView Classic is able to display attached image without changing "VIew / Pixel Ratio" setting.
XnView MP is not able to.
Could you please provide the option "Autodetect" for "Pixel Ratio" setting.
https://easyupload.io/nnazjb
Re: Autodetect pixel ratio
I'm not getting a download when I click the download button, am I missing something??
You could attach your ZIP of less than 2MiB directly to your post... :D
yacomi9014 wrote: Sun Oct 22, 2023 5:55 pm Could you please provide the option "Autodetect" for "Pixel Ratio" setting.
uncheck Adjust zoom if X/Y DPI are different
settings > general > general tab
however, I suggest you fix your image instead since it has incorrect horizontal & vertical DPIs:
- they are huge (2560x1920)
- they are not equal
set them to the same value, eg 72x72
viewer tab > image menu > set dpi...
