1.6.1 - viewer - incorrect rendering of image with unequal dpi
XnViewMP 1.6.1 64bit
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
incorrect rendering of image with unequal horizontal/vertical dpi
2. open test image (dpi H144 V72)
test_img.zip
(34.19 KiB) Downloaded 226 times
3. press SHIFT+R/L
4. zoom-out to any value between 51-99%
image will be displayed incorrectly
yacomi9014
Re: 1.6.1 - viewer - incorrect rendering of image with unequal dpi
Post by yacomi9014 »
Is this the same as viewtopic.php?p=193179 ?
nope, they both related to images with unequal horizontal&vertical dpi, however
  • my case
    there is a bug with rendering (color shift & stripes) of such images under certain conditions
fixed in 181
