1.6.1: Crashes since update from 1.5.5
vommie
Post by vommie »
XnView: 1.6.1 64 bit
OS: Arch Linux 64bit (Manjaro, Plasma)
XnViewMP crashes when I open a specific category
Effect: Program crashes
Actual behaviour (bug):
I can't describe it exactly because it's very random, but XnViewMP 1.6.1 crashes on me in some categories or folders. I've already tried to use the "strace" command to figure out if it happens with certain files, and it does, but not if I move the file and then call it up. So generating thumbnails or displaying the file itself is not the problem. Sometimes the program only crashes when I display the file within a category, but not when I display it by folder. It's very mysterious. I've tried to debug as much as possible but I can't make heads or tails of it. And it's not the RAM either, I've tested that too. But after downgrading back to 1.5.5, there are no crashes anymore. That's all I know :(
Re: 1.6.1: Crashes since update from 1.5.5
do you have folder/files when you have always the crash?
