Thumbnails on folder icons are displayed in landscape orientation instead of portrait orientation when taken with iPhone.
Screenshot attached.
I can provide sample images or sample files from the iPhone, but they are too large to attach here.
Edition Windows 10 Pro
Version 22H2
Betriebssystembuild 19045.3570
XnVIew 1.6.1 64bit
Thumbnails on folder icons are displayed rotated incorrectly
- Attachments
- folder pictures.jpg (32.04 KiB) Viewed 2059 times
Re: Thumbnails on folder icons are displayed rotated incorrectly
Thanks for the very fast solution
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
It now works perfectly for new folders.
It also works if you go to "Create new thumbnails". See screenshot.
But the existing thumbnails are not updated automatically.
Thanks again for the bugfix.
- Attachments
- Screenshot.jpg (31.66 KiB) Viewed 1756 times
