On macOS I can't open image files with german names that contain umlauts on cloud drives
visualnotes
Post by visualnotes »
Under macOS, I cannot open image files with German names containing umlauts on cloud drives.
If I have files with German names containing umlauts, such as "Käsekuchen.jpg" on a cloud storage like pCloud or Google Drive, I cannot open them with XnViewMP. The same goes for files with umlauts on FTP drives.
XnViewMP is not even able to create previews for files with such names.
However, as soon as I change the name from "Käsekuchen.jpg" to "Kaesekuchen.jpg", the image is displayed correctly.
It took me a while to figure out that this problem is not caused by the cloud storage, but by XnViewMP itself. The image viewer app "Lyn", for example, can open images with umlauts in the name on cloud drives without any problems. Also the preview app that comes with macOS can handle image files with German umlauts on cloud drives.
Since I want to use XnViewMP instead of Lyn to work with image files, it is extremely annoying that I have to rename all files with umlauts in their names to display them correctly.
I'm using the latest versions of macOS (currently Sonoma 14.0) and XnViewMP (v. 1.6.1).
Re: On macOS I can't open image files with german names that contain umlauts on cloud drives
i've tried on sonoma, and a file "Käsekuchen.jpg" on GoogleDrive is opened correctly...
BLang
Post by BLang »
Same here on Sequoia (15.5) and XnViewMP 1.9.2
Files stored in pCloud.
If the directory name is "König (T17)" I cannot open any file inside. Is it spelled "Koenig (T17)" it works fine.
regards
BLang wrote: Sun Jun 15, 2025 9:40 am If the directory name is "König (T17)" I cannot open any file inside. Is it spelled "Koenig (T17)" it works fine.
are you able to browse it?
BLang
Post by BLang »
I am not 100% sure what you mean.
In one of my screenshots I did browse it, right?
additional Info:
"open with..." and choosing different apps works fine (tested with chrome.app, safari.app, preview.app)
BLang
Post by BLang »
Now I think I understand what you mean...guess browsing with XnView
Yes, it works fine.
BLang wrote: Sun Jun 22, 2025 7:51 am Now I think I understand what you mean...guess browsing with XnView
Yes, it works fine.
and if you open from browser the image file, it works, i think?
BLang
Post by BLang »
No, it does not work. "File can't be loaded!" is the error message. Same as before.
BLang wrote: Sun Jun 22, 2025 12:23 pm No, it does not work. "File can't be loaded!" is the error message. Same as before.
i means from XnView's browser
BLang
Post by BLang »
yes, that's what I tried. Same error message if I try to open from the XnView Browser
BLang wrote: Sun Jun 22, 2025 2:32 pm yes, that's what I tried. Same error message if I try to open from the XnView Browser
when you click on a file, do you have info or preview in browser?
