Hi there. I am having some issues importing categories from a text file.
I have cleared the exisiting categories and then followed these steps: categories > categories management > import categories file > selected my .txt file.
Nothing happens and the categories do not appear. I've tried restarting XnView and my computer but no luck. Do anyone have any suggestions?
Many thanks!
Problem importing categories
Re: Problem importing categories
Try to create one category first ( right click in "caregories filter" pane) and then import your file.
Or try to create another txt file with a single word, and import...
Where is located your xnview.ini file ? (Settings... Integration tab)
Catalogage avec XnviewMP :
yvondar
bonjour,
Quel format doit avoir un fichier de catégories: séparateur entre catégories, entre sous catégories... retour chariot, tab ...
Merci de votre aide
Yvondar
Merci de votre aide
Yvondar
something like
Parent1
Child1
Child2
Parent2
