Convert TIFF to JPEG with skip
Agent2022
Post by Agent2022 »
Good afternoon. Is there an option in the converter to skip files with a different resolution? I have a folder in which there are tiff and jpeg images. Is it possible to make it so that when converting the program skips jpeg files and converts only tiff ?
Re: Convert TIFF to JPEG with skip
Agent2022 wrote: Wed Nov 01, 2023 8:10 am Is there an option in the converter to skip files with a different resolution? I have a folder in which there are tiff and jpeg images. Is it possible to make it so that when converting the program skips jpeg files and converts only tiff ?
To skip files with a different resolution? (Pixel dimensions?)
Or with a different extension?
In either case, I am confident that the option is not currently supported. But processing only files with a specified extension or specified extensions could be implemented using NConvert at the command line or in a batch file using wildcards, provided that all the required actions are supported.
You could if you wish post a Suggestion that support for file format selection be added to XnConvert, which if there is enough support might possibly be added by means of a filter either when input folders are selected, or when loaded folders are processed.
Agent2022
Post by Agent2022 »
cday wrote: Wed Nov 01, 2023 9:32 am
So that the converter would skip photos with the jpg extension and process only tiff.
Some of the files are scanned in tiff, some in jpg. Immediately load folders with files into the program and the program will skip jpg images and process only tiff
