Posts: 3159 Joined: Sat May 09, 2015 9:37 am
Post
by user0 » Thu Nov 02, 2023 8:29 am
XnViewMP 1.6.1 64bit
Formats dropdown
it is does not look nice when there are 2 lists joined togeter without any delimiter
add separator after most used formats
(shows only if ☑ 'Show most used format at begining' in Settings > Formats > Saving)
Related
Posts: 4617 Joined: Sun Apr 29, 2012 9:45 am
Post
by cday » Thu Nov 02, 2023 8:43 am
+1 with slightly bolder separator.
Posts: 6575 Joined: Sun Sep 25, 2005 3:00 am
Post
by XnTriq » Thu Nov 02, 2023 5:45 pm
I support this request.
ckit
Posts: 2600 Joined: Tue Feb 17, 2004 1:11 am
Post
by ckit » Thu Nov 02, 2023 11:14 pm
Supported but are BMP and TIFF still commonly used?
Post
by cday » Fri Nov 03, 2023 6:44 am
ckit wrote: Thu Nov 02, 2023 11:14 pm
The formats displayed can be selected in
Tools > Settings... > Formats > Saving tab -- Show most used formats at beginning ...
Posts: 48837 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Sun Nov 05, 2023 3:18 pm
not very easy to do. User can select separator
Post
by user0 » Sat Feb 03, 2024 5:27 am
xnview wrote: Sun Nov 05, 2023 3:18 pm
are you sure?
there is special function available:
QComboBox::insertSeparator
https://www.mimec.org/blog/qcombobox-with-separator wrote:In version 4.4 of Qt a long awaited feature was added to the QComboBox widget. It is now possible to create separator items, which are drawn as thin, gray lines and cannot be selected. Before 4.4 it was necessary to create a custom item delegate, and also to add a few hacks in order to correctly calculate the height of the popup list and to make it impossible to select the separator using up and down arrow keys. Now we can simply use the insertSeparator method.
example:
How to add separator in between the item of ComboBox
Post
by xnview » Mon Feb 05, 2024 2:56 pm
the save as dialog (Windows) doesn't use Qt
