Settings - formats - unify most used sets
XnViewMP 1.6.1 64bit
Settings - formats
combinations of buttons (Select all/Select most used) and 'Show most used format at begining' checkbox
produce different/unsorted 'most used' sets for some unknown reason
unify most used sets to:
- bmp
- heic
- jp2
- jpg
- jxl
- jxr
- png
- tif
- webp
although I'm not sure if the following are really most used:
- jp2
- jxl
- jxr
Related
Re: Settings - formats - unify most used sets
Perhaps better??
user0 wrote: Thu Nov 02, 2023 8:57 am - heic
- jp2
- jpg
- jxl
- png
- tif
- webp
looks good
tbh, maybe its just my experience, but:
- heic - looks like "read-only" format, not sure if anyone willingly convert any format into heic
- jp2 - I don’t remember if I’ve seen this format at least once in real life :D
masterjp
Post by masterjp »
Great idea.
HEIC/HEIF format is important for android smartphones / apple iphone photos, if you use it instead of jpeg files
Since the last update of XnViewMP 1.6.1 the avif (reading/writing) is more important than heif/heic.
The files are compatible with all popular browsers and the android 13 and later systems.
It get more important for internet sites or big photo collections on tablet/smartphone.
You can save at least 25% more space in comparison to jpeg or webp at the same quality.
JPEG XL (JXL) is interesting for big digital photos so save space on hdd.
It is a great format, but need some further time to get successful as other formats.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
fixed in 162
