Missing filter by Ratings
revaaron
Post by revaaron »
For some reason, I cannot filter by Rating in View > Filter by on my laptop. This is the function that makes XnView so critical for me - I can quickly and easily run through JPEGs, tag the ones I like an the ones I want to delete with a 5 or 1 star rating, and then filter by those ratings to process further. The other filter options show up as expected - see screenshot.
I've run through the Settings many times, but can't find a setting where I may have accidentally disabled filtering by Ratings.
I tried deleting my settings folder ("C:\Users\rev\AppData\Roaming\XnViewMP") and starting again from scratch. Still, not Ratings in the filter box.
I'm currently running 1.5.5. Just updated to the latest 1.6.1 and the issue is still there. I run an older version of XnView MP 1.3.1 - using the portable ZIP rather than installed - on another PC, configured the same way (mostly). I don't have this issue with that instance. I've even copied the app's folder to the new PC - Ratings show up as they should there.
Any ideas?
Re: Missing filter by Ratings
check top right corner of Filelist toolbar
Settings>Browser>Toolbar - rating
revaaron
Post by revaaron »
xnview wrote: Mon Nov 06, 2023 6:57 am Settings>Browser>Toolbar - rating
I have "Rating" checked - see screenshot.
revaaron
Post by revaaron »
And oddly enough, even though there are no Rating entries in the Filter by menu, there is a Rating & Colour label entry with the menu, complete with ratings. They work fine for setting the rating. There is just no way to filter by Rating.
revaaron
Post by revaaron »
user0 wrote: Mon Nov 06, 2023 6:36 am check top right corner of Filelist toolbar
That works - thank you!
