1.6.1 - viewer - selection - incorrect position of size indicator while zooming
XnViewMP 1.6.1
Viewer - selection
1. open any image in Viewer
issue A
2. make selection and do not release LMB
3. zoom-in/out with mouse wheel
image will be zoomed-in/out
selection will disappear, but size indicator still shows
expected behaviour
guess selection should not disappear as it does not disappear when you drag selection and zoom (see issue B)
issue B
2. make selection smaller than image
3. start dragging selection
4. zoom-in/out with mouse wheel
image and selection will be zoomed-in/out
selection size indicator will remain in the same place, detached from the selection corner
expected behaviour
selection size indicator should stick to selection corner
Related
