Squeezing more lines into list of items- how to use vertical space more efficiently?
The Electro Machine
Post by The Electro Machine »
Recently I have finally managed to increasing the size of font for the main window which lists all items in a folder [viewtopic.php?f=60&t=32721&p=193586#p193586]
But how can I reduce the vertical space between each line? I reckon I need to add or change some padding value in the
C:\Users\YOUR-USER-NAME\AppData\Roaming\XnViewMP\style_sheet.qss
file - but which one?
The same question goes for the Folders side panel, the one which can be turned on / off by going to
View > Panels > Folders
Last edited by The Electro Machine on Sat Jan 06, 2024 11:28 am, edited 1 time in total.
The Electro Machine
Re: Squeezing more lines into list of items- how to use vertical space more efficiently
Well, does anyone knows an answer to this?
