counting images
faro347
counting images
Is there a way to see how many images are located in my files without my counting each one separately. This would be a big time saver when I have two files that might have the same images in them, put there by mistake. I am using XnView on a mac desktop with m1 chip. Thanks
Re: counting images
you would like to have the number of files in a folder?
faro347
Re: counting images
Yes, I would like to be able to see a count of the images in a folder. Thank you
Re: counting images
Browser > Edit menu > Select all images
1. assign Shortcut to this command, eg CTRL+I as in ACDSee
2. press Shortcut key(s) when in folder
check "selected objects'" counter in status bar
Re: counting images
A useful workaround, but if the count can be easily added to the default interface that would probably be better?
faro347
Re: counting images
Thanks for the info, but I am unable to create a shortcut even though it appears that I have done that. But why would I need to creat a shortcut after I selected all the images? Shouldn’t that enable me to click “selected objects” in the status bar? It would be great to add the counting ability as a default.
Re: counting images
I don't have a simple solution that I'm happy with.cday wrote: Tue Nov 21, 2023 4:02 pm A useful workaround, but if the count can be easily added to the default interface that would probably be better?
Also, keep in mind, the next thing that will be suggested - add counters for:
- tagged files
- folders
you do not need to; there are 2 options, you may use any of themfaro347 wrote: Tue Nov 21, 2023 5:23 pm But why would I need to creat a shortcut after I selected all the images?
no, clicking on statusbar should not select anythingfaro347 wrote: Tue Nov 21, 2023 5:23 pm Shouldn’t that enable me to click “selected objects” in the status bar?
faro347
Re: counting images
Again, thanks for trying to be helpful. But I am still at sea with this. Perhaps in the next iteration of XnView there will be a way to have a one-click count of the images in my folders. Like the software very much; my post was a thought that occurred when I wondered if there is a button that I was missing to give me an image count. Keep up the good work.
Re: counting images
I have an idea how to fit stats into the statusbar - move it to the right side
- as it does not fit left side logically when there are selected objects
- so it does not overwhelm left side
Browser mode
StatusBar - viewer - move position/selection to the right (1.8.1)
ps. also I would align items to grid to fix their position (A)
Browser mode
- left side
- truncate 'object(s) selected' to 'selected'
- right side
- move from left side
- free disk space
- add counters (current folder stats)
can be represented by icons
- folders
- files (not shown)
- images
- tagged
