rc1: [bug] delete in browser treeview doesn't work
FlorianH
Post by FlorianH »
1) select folder in treeview (content is displayed in file list)
2) select delete from context menu in treeview -> dialog: realy delete -> yes
3) takes some seconds -> OS message: access denied
...because folder is in use by xnview -> xnview should change folder before deleting folder...
XnView 1.82 -
marsh
Post by marsh »
Deleting currently used directory with folder tree works for me in details view, but not thumbnail view. And, using the <del> key does not work on tree folder.
ckit
Post by ckit »
marsh wrote:Deleting currently used directory with folder tree works for me in details view, but not thumbnail view. And, using the <del> key does not work on tree folder.
Confirmed.
ckit
Post by ckit »
Bug still exists in RC2.
ckit wrote:Bug still exists in RC2.
You have always the problem when deleting the current folder in treeview menu?
