Batch convert settings dialog
ray_gurganus
Post by ray_gurganus »
In the Batch convert settings dialog there are 14 file types. I only use 1 (JPEG), and it is annoying and potentially dangerous that it does not show as the default. So it would make sense that either (1) types not needed can could be disabled and hidden, or (2) it remembers which one was last used, and defaults to that. Otherwise, it is tempting to just adjust the default (which is always AVIF, and not needed), vs remembering to change tabs.
Re: Batch convert settings dialog
ray_gurganus wrote: Sat Nov 18, 2023 9:51 pm (2) it remembers which one was last used...
+1 Persistence of settings where appropriate, ideally considered when a new interface is designed...
sorry but i don't understand, output format is the last used
