Add "Add Fields" to "Add Text"
burnuser
Post by burnuser »
It would be great if an "Add Fields" option is added to "Add Text" like in "Caption" in Print dialog or in "QR-Code" in batch convert. (Or like in IrfanView)
Especially in batch convert, Fields could enable automatic inserting of Filename, Creation date or EXIF/IPTC/XMP Metadata as visible Text in the image.
Re: Add "Add Fields" to "Add Text"
Post by michel038 »
It's already possible, use the right-arrow-menu on the right side of the text box ...
burnuser
Post by burnuser »
Yes, You are right.
I tried it in image view with no result, and had it overseen afterwards in batch convert. Sorry.
It is only missing in image view.
