1.6.1 - create multi-page file - tiff settings - Metadata checkboxes are broken
XnViewMP 1.6.1 64bit
Browser - create multi-page file
broken Metadata checkboxes in format Write dialog
1. open 'Multi-page file...' in Browser > Create menu
2. select TIFF format
3. press Settings button
4. click on Metadata checkboxes in 'Write settings' dialog
checkboxes behaviour is broken
masterjp
Re: 1.6.1 - create multi-page file - tiff settings - Metadata checkboxes are broken
Post by masterjp »
How do you want to use meta datas (e.g. EXIF) from different files in one new tif picture file?
As far as I know it is only possible to save one meta data in the new multi-page file.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
OP issue is about controls broken behavior, try to click on them multiple times to see what I mean.
I do not need metadata at all, but if metadata saving functionality is there already, I guess it shall use 1st file as source.
:bugconfirmed:
i can't reproduce on 1.6.2
I can reproduce on 1.6.2
try to check/uncheck all "Keep .." options from top to bottom and to top again.
It only happens with TIFF write settings in 'Multi-page file...' dialog.
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
fixed in 163
