Save as ... Guetzli jpg
Tschens
Post by Tschens »
when using the "save as" to save a guetzli-compressed jpg, I can choose quality between 0 and 100 as well as "progressive" jpg. However, Guetzli does not support that. Whats going on here and why is it possible without getting an error message that guetzli needs quality setting >= 84?
Thanks,
Jens
Olympus OMD E-M1, BS Kinetics underwater housing, 2xSubtronic pro 160 flashes. Zuiko mFT lenses: 60 macro, 7-14, 8 mm fisheye, 12-100, PanaLeica 100-400.
My Homepage | My book at Amazon
Re: Save as ... Guetzli jpg
yes right, currently guetzli use same options dialog as jpeg
Tschens
Post by Tschens »
But this should not work. However, if I chose quality below 84 and "progressive", I get an exported jpg anyway. Whats going on? Is guetzli bypassed in thess cases?
