I found that when copying duplicate files, the original gif format cannot be changed to other formats. The changed other formats will be displayed as errors in File Explorer, but non-gif formats can be changed to other formats.
P.S. any version
Duplicate gif files cannot be formatted
alee001
Re: Duplicate gif files cannot be formatted
i don't understand you can't change the extension of gif?
alee001
If I can directly change the duplicate files from gif to jpg, I can skip the steps of batch conversion and deletion.
The following is the error after changing the duplicate file from gif to jpg:
if you change only extension the file is not converted
alee001
If the format cannot be converted, what is the use of setting this extension format?
alee001
Normally there is no need to change the extension, unless it can change the format, it is recommended to disable it.
alee001
If other extensions are not applicable, perhaps they should be disabled to avoid being mistaken for a convertible format?xnview wrote: Sun Nov 26, 2023 7:25 am for example, jpeg file can have extension .jpg, .jpeg, .jif, .JPG
