The problem is this...the thumbnails (thumbnail) are of poor quality
BEELINEUA
Post by BEELINEUA »
Hello
The problem is this...the thumbnails (thumbnail) are of poor quality, although the picture itself is excellent, what could be the problem, or is it like this for everyone??
Use High Quality setting enabled
Re: The problem is this...the thumbnails (thumbnail) are of poor quality
what do you have as thumbnail size? and in settings>Catalog - thumbnail size?
BEELINEUA
Post by BEELINEUA »
xnview wrote: Sun Nov 26, 2023 7:28 am what do you have as thumbnail size? and in settings>Catalog - thumbnail size?
290x234
BEELINEUA wrote: Sun Nov 26, 2023 8:08 am 290x234
View>Thumbnail size too?
BEELINEUA
Post by BEELINEUA »
xnview wrote: Sun Nov 26, 2023 9:21 am
This option has been disabled. I turned it on and set it to the same size, but nothing changed. Cleared thumbnail cache
disabled?? i means in the menu
BEELINEUA
Post by BEELINEUA »
xnview wrote: Sun Nov 26, 2023 10:37 am disabled?? i means in the menu
Yes
Can you show your thumbnail settings in the menu?
