problem with dispalying comments/caption
folder
Post by folder »
Both files contains comments/captions.
But only after resave with Photoshop, XnViewMP displays them.
I used versions from 1.4.0 to the latest 1.6.2.
I understand, that it is a problem with position of tag inside image, but windows explorer recognizes it correctly..
i need to sort images by comments/caption, how to fix this?
Thanks!
Re: problem with dispalying comments/caption
could you send me the files?
folder
Post by folder »
xnview wrote: Mon Nov 27, 2023 7:21 am could you send me the files?
sent via pm
Spirou4D
Post by Spirou4D »
One workaround I found is to use a tool like Exif Pilot or ExifTool to edit the comment/caption tags directly. Sometimes, XnViewMP doesn't read them correctly, but if you manually update the tags, it should help you sort your images based on comments/captions.
folder
Post by folder »
Spirou4D wrote: Wed Nov 29, 2023 8:58 am One workaround I found is to use a tool like Exif Pilot or ExifTool to edit the comment/caption tags directly. Sometimes, XnViewMP doesn't read them correctly, but if you manually update the tags, it should help you sort your images based on comments/captions.
thanx for your reply!
yes, i know the tools. exiftool is a great for mass meta read/write.
i like xn, my main viewer\sorter\editor. it's developing regularly, growing up, has a large community and skilled author.
want to use it further.
The image file not written by PS, has no IPTC metadata and store 'Note: Wolff' in 'EXIF:Image Description' not in 'IPTC:Cpation'
folder
Post by folder »
xnview wrote: Fri Dec 01, 2023 7:40 am The image file not written by PS, has no IPTC metadata and store 'Note: Wolff' in 'EXIF:Image Description' not in 'IPTC:Cpation'
152342 is an "original" file, written by phone software. windows explorer reads metadata. xn doesnt.
152630 was opened in PS, then just only saved. windows explorer reads metadata. so does xn. PS copied metedata to IPTC:Caption and XMP:Description :)
ok, can you add an ability to display EXIF:Image Description. And do you plan to add XMP tags?
folder wrote: Fri Dec 01, 2023 3:23 pm ok, can you add an ability to display EXIF:Image Description. And do you plan to add XMP tags?
yes soon
folder
Post by folder »
xnview wrote: Sat Dec 02, 2023 10:01 am
yes soon
Dear author, any news?)
you can use {XMP:tag} already
folder
Post by folder »
ok) what about "EXIF:Image Description" or "EXIF:User comment" сolumn in details view-mode?
