This is a regression; I cannot reproduce the bug in 1.4.5.
I believe the bug started to appear around 1.6.x.
When converting image with the following setting (see also the attachment for the saved preset):
The output file shouldn't need to be renamed to {filename}_01 because the original files are deleted.
However, it will generate outputs with {filename}_01 filenames.
This only happens when I enable "Use multiple CPU Cores".
1.6.2: batch convert unnecessary rename when using multi-core
fireattack
Re: 1.6.2: batch convert unnecessary rename when using multi-core
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
