1.6.2 Flash on screen when entering full screen mode
Mark1342
Post by Mark1342 »
XnView MP: 1.6.2 64-bit (Windows)
OS: Windows 11 - 64-bit
When entering full screen mode there is usually a momentary white flash of two horizontal bars at top and bottom of the screen just before the Full screen image appears
Effect: Display glitch
1. Browse to a folder with images (mine were jpg)
2. Select one of the image files.
3. Open fullscreen (view) using either F11 key or View->Fullscreen
Actual behaviour (bug): Momentary white flash (top and bottom) just before image appears
Expected behaviour: No white flash before the image appears
Re: 1.6.2 Flash on screen when entering full screen mode
i can't reproduce, could you send me your .ini?
Mark1342
Post by Mark1342 »
xnview.ini attached
Perhaps I ought to have added I use portable zip version, set a black background.
I have xnview MP it on three computers, it happens on all of them.
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
