XnView and PSElements problem [Solved]
faro347
Post by faro347 »
Subject: 0.99.7:Images do not open in PS Elements
XnView: 1.6.2
OS: Mac 64 bit
<Short description of the problem.>clicking on an image should open it in ps elements
Effect: Images do not open as expected. They will open if I move them manually.
1. click on an image
2.choose software which normally will open the image; in my case Photoshop Elements 2024
3. nothing happens. i have to go to elements, click on open, find the image I want to open and then the image will go to raw, for example, or directly into elements as expected. this behavior is pretty new, a few days old, I believe; the click and open worked before.
Actual behaviour (bug): <Current wrong behaviour of XnView> :bug:
Expected behaviour: <Expected, correct behaviour of XnView>
_
Re: XnView and PSElements problem
you means with 'open with'?
faro347
Post by faro347 »
Yes, Pierre. Clicking on "open with" does not work.
and with other apps, it works?
faro347
Post by faro347 »
Good day, Pierre. Yes, the software works to open PSElements 2022, but not PSE 2024, the newest version. XnView does allow me to open in Bridge 2024 and then from Bridge I can open the image in Elements. I much prefer using your program than Bridge :!:
faro347
Post by faro347 »
Problem continues and now Elements 2022 will not open using XnView. I have to pull the file from Finder to open in any version of Elements. Any ideas what's causing this, Pierre? Thanks.
faro347 wrote: Wed Dec 27, 2023 7:22 pm Problem continues and now Elements 2022 will not open using XnView. I have to pull the file from Finder to open in any version of Elements. Any ideas what's causing this, Pierre? Thanks.
try to start XnView from a terminal, and send the logs when you try to open with PSE
faro347
Post by faro347 »
Thank you. I don't know how to start XnView from a terminal. Will you please send me some instructions?
open the context menu on XnViewMP package, 'show package content'
go to Contents/MacOS
Choose XnViewMP, 'open with>Terminal'
faro347
Post by faro347 »
Pierre,
I am baffled by this. I cannot find "show package content" at all. I have searched on the context menu and also on About XnView with no results. :(
faro347
Post by faro347 »
Newest XnView version now also prevents my opening PSElements 2022. Now both Elements 2024 and 2022 do not open from XnView 1.6.4.
faro347
Post by faro347 »
I think this is what you are asking for, Pierre??
Last login: Mon Jan 15 09:22:25 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
Shadelands-iMac:~ test$ /Applications/XnViewMP.app/Contents/MacOS/XnViewMP ; exit;
0.24.0 (git 747da87) - Multimedia Development Kit. Copyright (c) 2016-2023 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: macOS110000/14.2.1 ARMv8 AArch64; AppleClang14.0.3 (clang-1403.0.22.14.1)GCC4.2.1; libc++15006; 11:10:20 Dec 31 2023
==> 2.000000  2.000000  109.000002  72.000000  (1)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 2240 1207
2024-01-15 14:43:37.059 XnViewMP[12095:227552] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
XNVIEW SIZE 2240 1207
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x600003fb5b00
ThumbLoaderThread :: stop()
qt.gui.icc: fromIccProfile: failed minimal tag size sanity
QPngHandler: Failed to parse ICC profile
###### CHECK CHILDRENS 0
  ###### CHECK CHILDRENS ok (0)
QWidget::setMinimumSize: (favoriteD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (categoryD/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (prevD/QDockWidget) Negative sizes (0,-1) are not possible
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (2240 1207)
BrowserWindow :: restoreState => 2240 1207
                              => 1983 956
BrowserWindow :: restoreState ok => 1983 956
XNVIEW SIZE ok 2240 1207
### BrowserWindow :: onStart go
#### onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (2240 1186)
BrowserWindow :: restoreState => 2240 1186
                              => 1906 997
BrowserWindow :: restoreState ok => 1906 747
QObject::connect: Cannot queue arguments of type 'QList<int>'
(Make sure 'QList<int>' is registered using qRegisterMetaType().)
BrowserWindow :: onStart 2
setPathname </>
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 6f4220
######ThumbLoaderThread :: forever : 6f4220
 ** start condition wait
### ThumbLoaderThread :: setFileList() after wait
 ** start condition wake one 2
## OPEN FOLDER
######ThumbLoaderThread :: forever 2 : 6f4220
CHECK <0>
## Check folder
  ## Check companion  0
  ## Check companion ok  0
  ## OPEN DB FOLDER ok  0
  ## UPDATE DB FOLDER ok  0
  ## OPEN FOLDER ok  0
## updateLabel  0
## updateLabels ok  2
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
BitmapLoadThread :: stop()
@@ BitmapResizeThread:: clear
Create children /
## OPEN FOLDER done  5
### ThumbLoaderThread :: setFileList(4)
CHECK <4>
### START 4
######ThumbLoaderThread :: start : 4     -1 -1
### BrowserWindow :: finish
sizeHints : 266
#### onCategoryFilterDockVisible (0)
Create children /Volumes/
Create children /Volumes/T7 Photos/
###### CHECK CHILDRENS 51
## UPDATE ==> (Architecture)
setPathname </Volumes/T7 Photos/Architecture/>
## OPEN FOLDER
CHECK <0>
## Check folder
  ## OPEN DB FOLDER ok  2
  ## UPDATE DB FOLDER ok  2
  ## OPEN FOLDER ok  2
## updateLabel  2
## updateLabels ok  42
######### CategoryModel :: checkAndSave()
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
## OPEN FOLDER done  92
### ThumbLoaderThread :: setFileList(128)
CHECK <128>
### START 128
######ThumbLoaderThread :: start : 128     -1 -1
LOAD BITMAP </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg>
GFF :: LoadThumbnail : 626 512  (0)
LOADED & CREATED
sizeHints : 266
BLOB length 126
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA crop 2.tif>
GFF :: LoadThumbnail : 633 483  (0)
LOADED & CREATED
BLOB length 1622
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA crop.tif>
GFF :: LoadThumbnail : 637 380  (0)
LOADED & CREATED
BLOB length 1624
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA X copy_edited-1.tif>
GFF :: LoadThumbnail : 609 512  (0)
LOADED & CREATED
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
BLOB length 2265
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA X copy.tif>
LOADED & CREATED
BLOB length 2258
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA X Palette.tif>
LOADED & CREATED
BLOB length 2260
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA X.tif>
LOADED & CREATED
BLOB length 2251
LOAD BITMAP </Volumes/T7 Photos/Architecture/3 Figures SFMOMA.tif>
GFF :: LoadThumbnail : 638 479  (0)
LOADED & CREATED
BLOB length 1540
LOAD BITMAP </Volumes/T7 Photos/Architecture/47 New Montgomery.JPG>
GFF :: LoadThumbnail : 160 120  (0)
LOADED & CREATED
BLOB length 458
LOAD BITMAP </Volumes/T7 Photos/Architecture/advert - blackfriars bridge, london.jpg>
GFF :: LoadThumbnail : 338 512  (0)
LOADED & CREATED
BLOB length 843
LOAD BITMAP </Volumes/T7 Photos/Architecture/Architect's Offices_5713.psd>
  JPEG load : 0.164577  638 512
  JPEG load : 256 210
GFF :: LoadThumbnail : 256 210  (0)
LOADED & CREATED
BLOB length 1886
LOAD BITMAP </Volumes/T7 Photos/Architecture/Architectures - San Francisco.jpg>
GFF :: LoadThumbnail : 153 156  (0)
LOADED & CREATED
BLOB length 14223
LOAD BITMAP </Volumes/T7 Photos/Architecture/Architectures - San Francisco.tif>
*********** UPDATE MODEL ****************
         0
*********** UPDATE MODEL **************** ok   0
MyView::set LOAD FULL /Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg
LOAD INFO </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg>
  LOAD INFO </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> ok
BitmapLoadThread: load preview 100 30  (0)
## BitmapLoadThread :: load 100 30
## Bitmap :: load 2048
###### GFF:load </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg>
####LOAD </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg>  0
  ## BitmapLoadThread :: loaded 184 150
BitmapLoadThread: load full
## BitmapLoadThread :: load -1 -1
## Bitmap :: load 0
  ## BitmapLoadThread :: loaded 734 600
## MyView::onLoaded </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> (0)
## MyView::onLoaded ok
### resetViewport (0x14d9a4e00)  ==> 100 30  (37 30) 0 0
############################################ InfoPropertiesView
Create Tree : File
Create Tree : Image
Create Tree : Color Profile
##### BUILD HISTO
##### BUILD HISTO ok
## MyView::onLoaded </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> <> </Volumes/T7 Photos/Architecture/{Q-E}Architect's Offices_5713.jpg> (1)
GFF :: LoadThumbnail : 503 512  (0)
LOADED & CREATED
BLOB length 1774
LOAD BITMAP </Volumes/T7 Photos/Architecture/Berkeley brick_NIKed.tif>
         0
LOADED & CREATED
BLOB length 3408
LOAD BITMAP </Volumes/T7 Photos/Architecture/Berkeley brick.jpg>
LOADED & CREATED
BLOB length 11509
LOAD BITMAP </Volumes/T7 Photos/Architecture/Berkeley House.JPG>
LOADED & CREATED
BLOB length 1448
LOAD BITMAP </Volumes/T7 Photos/Architecture/Berkeley_edited.jpg>
GFF :: LoadThumbnail : 159 160  (0)
LOADED & CREATED
BLOB length 2496
LOAD BITMAP </Volumes/T7 Photos/Architecture/Berkeley.jpg>
GFF :: LoadThumbnail : 510 512  (0)
LOADED & CREATED
BLOB length 2075
LOAD BITMAP </Volumes/T7 Photos/Architecture/bridge (Medium).jpg>
GFF :: LoadThumbnail : 127 128  (0)
LOADED & CREATED
BLOB length 330
LOAD BITMAP </Volumes/T7 Photos/Architecture/bridge_edited.jpg>
GFF :: LoadThumbnail : 158 160  (0)
LOADED & CREATED
BLOB length 345
LOAD BITMAP </Volumes/T7 Photos/Architecture/bridge.jpg>
LOADED & CREATED
BLOB length 7592
LOAD BITMAP </Volumes/T7 Photos/Architecture/Chimney-001.JPG>
LOADED & CREATED
BLOB length 1567
LOAD BITMAP </Volumes/T7 Photos/Architecture/Chimney.JPG>
LOADED & CREATED
BLOB length 1567
LOAD BITMAP </Volumes/T7 Photos/Architecture/Crane - San Francisco.JPG>
LOADED & CREATED
BLOB length 1584
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design San Francisco.JPG>
LOADED & CREATED
BLOB length 458
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design San Francisco.tif>
         0
*********** UPDATE MODEL **************** ok   1
GFF :: LoadThumbnail : 506 512  (0)
LOADED & CREATED
BLOB length 3800
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design SF State_crop 2.tif>
GFF :: LoadThumbnail : 486 512  (0)
LOADED & CREATED
BLOB length 2442
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design SF State_crop.tif>
         0
GFF :: LoadThumbnail : 410 512  (0)
LOADED & CREATED
BLOB length 2432
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design SF State.JPG>
         0
LOADED & CREATED
BLOB length 1962
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design SF State.tif>
         0
GFF :: LoadThumbnail : 504 512  (0)
LOADED & CREATED
BLOB length 2436
LOAD BITMAP </Volumes/T7 Photos/Architecture/Design SF State0001.JPG>
###  checkChanged : 0
         0
LOADED & CREATED
BLOB length 1058
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2026.psd>
         0
GFF :: LoadThumbnail : 638 478  (0)
LOADED & CREATED
BLOB length 3451
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2026.RAF>
=> 1 f000: d 1
=> 2 f001: 4 1
=> 2 f002: 4 1
=> 2 f003: 4 1
=> 2 f004: 4 1
=> 2 f005: 4 1
=> 2 f006: 4 1
=> 2 f007: 4 1
=> 2 f008: 4 1
=> 2 f009: 4 1
=> 2 f00a: 4 4
=> 2 f00b: a 23
=> 2 f00c: 4 8
=> 2 f00d: 4 3
=> 2 f00e: 4 3
=> 2 f00f: a 31
=> 2 f010: a 23
=> 3 10f: 2 9
=> 3 110: 2 4
=> 3 112: 3 1
=> 3 11a: 5 1
=> 3 11b: 5 1
=> 3 128: 3 1
=> 3 131: 2 27
=> 3 132: 2 20
=> 3 213: 3 1
=> 3 8298: 2 5
=> 3 8769: 4 1
=> 0 829a: 5 1
=> 0 829d: 5 1
=> 0 8822: 3 1
=> 0 8827: 3 1
=> 0 8830: 3 1
=> 0 9000: 7 4
=> 0 9003: 2 20
=> 0 9004: 2 20
=> 0 9101: 7 4
=> 0 9102: 5 1
=> 0 9201: a 1
=> 0 9202: 5 1
=> 0 9203: a 1
=> 0 9204: a 1
=> 0 9205: 5 1
=> 0 9207: 3 1
=> 0 9208: 3 1
=> 0 9209: 3 1
=> 0 920a: 5 1
=> 0 927c: 7 870
=> 0 a000: 7 4
=> 0 a001: 3 1
=> 0 a002: 4 1
=> 0 a003: 4 1
=> 0 a005: 4 1
=> 0 40001: 2 4
=> 0 40002: 7 4
=> 0 a20e: 5 1
=> 0 a20f: 5 1
=> 0 a210: 3 1
=> 0 a217: 3 1
=> 0 a300: 7 1
=> 0 a301: 7 1
=> 0 a401: 3 1
=> 0 a402: 3 1
=> 0 a403: 3 1
=> 0 a406: 3 1
=> 0 a40a: 3 1
=> 0 a40c: 3 1
=> 3 c4a5: 7 106
=> 4 103: 3 1
=> 4 112: 3 1
=> 4 11a: 5 1
=> 4 11b: 5 1
=> 4 128: 3 1
=> 4 201: 4 1
=> 4 202: 4 1
=> 4 213: 3 1
LOADED & CREATED
BLOB length 979
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2026a.jpg>
LOADED & CREATED
BLOB length 992
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2028.RAF>
=> 1 f000: d 1
=> 2 f001: 4 1
=> 2 f002: 4 1
=> 2 f003: 4 1
=> 2 f004: 4 1
=> 2 f005: 4 1
=> 2 f006: 4 1
=> 2 f007: 4 1
=> 2 f008: 4 1
=> 2 f009: 4 1
=> 2 f00a: 4 4
=> 2 f00b: a 23
=> 2 f00c: 4 8
=> 2 f00d: 4 3
=> 2 f00e: 4 3
=> 2 f00f: a 31
=> 2 f010: a 23
=> 3 10f: 2 9
=> 3 110: 2 4
=> 3 112: 3 1
=> 3 11a: 5 1
=> 3 11b: 5 1
=> 3 128: 3 1
=> 3 131: 2 27
=> 3 132: 2 20
=> 3 213: 3 1
=> 3 8298: 2 5
=> 3 8769: 4 1
=> 0 829a: 5 1
=> 0 829d: 5 1
=> 0 8822: 3 1
=> 0 8827: 3 1
=> 0 8830: 3 1
=> 0 9000: 7 4
=> 0 9003: 2 20
=> 0 9004: 2 20
=> 0 9101: 7 4
=> 0 9102: 5 1
=> 0 9201: a 1
=> 0 9202: 5 1
=> 0 9203: a 1
=> 0 9204: a 1
=> 0 9205: 5 1
=> 0 9207: 3 1
=> 0 9208: 3 1
=> 0 9209: 3 1
=> 0 920a: 5 1
=> 0 927c: 7 870
=> 0 a000: 7 4
=> 0 a001: 3 1
=> 0 a002: 4 1
=> 0 a003: 4 1
=> 0 a005: 4 1
=> 0 40001: 2 4
=> 0 40002: 7 4
=> 0 a20e: 5 1
=> 0 a20f: 5 1
=> 0 a210: 3 1
=> 0 a217: 3 1
=> 0 a300: 7 1
=> 0 a301: 7 1
=> 0 a401: 3 1
=> 0 a402: 3 1
=> 0 a403: 3 1
=> 0 a406: 3 1
=> 0 a40a: 3 1
=> 0 a40c: 3 1
=> 3 c4a5: 7 106
=> 4 103: 3 1
=> 4 112: 3 1
=> 4 11a: 5 1
=> 4 11b: 5 1
=> 4 128: 3 1
=> 4 201: 4 1
=> 4 202: 4 1
=> 4 213: 3 1
LOADED & CREATED
BLOB length 979
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2032.RAF>
=> 1 f000: d 1
=> 2 f001: 4 1
=> 2 f002: 4 1
=> 2 f003: 4 1
=> 2 f004: 4 1
=> 2 f005: 4 1
=> 2 f006: 4 1
=> 2 f007: 4 1
=> 2 f008: 4 1
=> 2 f009: 4 1
=> 2 f00a: 4 4
=> 2 f00b: a 23
=> 2 f00c: 4 8
=> 2 f00d: 4 3
=> 2 f00e: 4 3
=> 2 f00f: a 31
=> 2 f010: a 23
=> 3 10f: 2 9
=> 3 110: 2 4
=> 3 112: 3 1
=> 3 11a: 5 1
=> 3 11b: 5 1
=> 3 128: 3 1
=> 3 131: 2 27
=> 3 132: 2 20
=> 3 213: 3 1
=> 3 8298: 2 5
=> 3 8769: 4 1
=> 0 829a: 5 1
=> 0 829d: 5 1
=> 0 8822: 3 1
=> 0 8827: 3 1
=> 0 8830: 3 1
=> 0 9000: 7 4
=> 0 9003: 2 20
=> 0 9004: 2 20
=> 0 9101: 7 4
=> 0 9102: 5 1
=> 0 9201: a 1
=> 0 9202: 5 1
=> 0 9203: a 1
=> 0 9204: a 1
=> 0 9205: 5 1
=> 0 9207: 3 1
=> 0 9208: 3 1
=> 0 9209: 3 1
=> 0 920a: 5 1
=> 0 927c: 7 870
=> 0 a000: 7 4
=> 0 a001: 3 1
=> 0 a002: 4 1
=> 0 a003: 4 1
=> 0 a005: 4 1
=> 0 40001: 2 4
=> 0 40002: 7 4
=> 0 a20e: 5 1
=> 0 a20f: 5 1
=> 0 a210: 3 1
=> 0 a217: 3 1
=> 0 a300: 7 1
=> 0 a301: 7 1
=> 0 a401: 3 1
=> 0 a402: 3 1
=> 0 a403: 3 1
=> 0 a406: 3 1
=> 0 a40a: 3 1
=> 0 a40c: 3 1
=> 3 c4a5: 7 106
=> 4 103: 3 1
=> 4 112: 3 1
=> 4 11a: 5 1
=> 4 11b: 5 1
=> 4 128: 3 1
=> 4 201: 4 1
=> 4 202: 4 1
=> 4 213: 3 1
LOADED & CREATED
BLOB length 979
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2034.RAF>
=> 1 f000: d 1
=> 2 f001: 4 1
=> 2 f002: 4 1
=> 2 f003: 4 1
=> 2 f004: 4 1
=> 2 f005: 4 1
=> 2 f006: 4 1
=> 2 f007: 4 1
=> 2 f008: 4 1
=> 2 f009: 4 1
=> 2 f00a: 4 4
=> 2 f00b: a 23
=> 2 f00c: 4 8
=> 2 f00d: 4 3
=> 2 f00e: 4 3
=> 2 f00f: a 31
=> 2 f010: a 23
=> 3 10f: 2 9
=> 3 110: 2 4
=> 3 112: 3 1
=> 3 11a: 5 1
=> 3 11b: 5 1
=> 3 128: 3 1
=> 3 131: 2 27
=> 3 132: 2 20
=> 3 213: 3 1
=> 3 8298: 2 5
=> 3 8769: 4 1
=> 0 829a: 5 1
=> 0 829d: 5 1
=> 0 8822: 3 1
=> 0 8827: 3 1
=> 0 8830: 3 1
=> 0 9000: 7 4
=> 0 9003: 2 20
=> 0 9004: 2 20
=> 0 9101: 7 4
=> 0 9102: 5 1
=> 0 9201: a 1
=> 0 9202: 5 1
=> 0 9203: a 1
=> 0 9204: a 1
=> 0 9205: 5 1
=> 0 9207: 3 1
=> 0 9208: 3 1
=> 0 9209: 3 1
=> 0 920a: 5 1
=> 0 927c: 7 870
=> 0 a000: 7 4
=> 0 a001: 3 1
=> 0 a002: 4 1
=> 0 a003: 4 1
=> 0 a005: 4 1
=> 0 40001: 2 4
=> 0 40002: 7 4
=> 0 a20e: 5 1
=> 0 a20f: 5 1
=> 0 a210: 3 1
=> 0 a217: 3 1
=> 0 a300: 7 1
=> 0 a301: 7 1
=> 0 a401: 3 1
=> 0 a402: 3 1
=> 0 a403: 3 1
=> 0 a406: 3 1
=> 0 a40a: 3 1
=> 0 a40c: 3 1
=> 3 c4a5: 7 106
=> 4 103: 3 1
=> 4 112: 3 1
=> 4 11a: 5 1
=> 4 11b: 5 1
=> 4 128: 3 1
=> 4 201: 4 1
=> 4 202: 4 1
=> 4 213: 3 1
LOADED & CREATED
BLOB length 3018
LOADED & CREATED
BLOB length 75
LOAD BITMAP </Volumes/T7 Photos/Architecture/DSCF2035.RAF>
=> 1 f000: d 1
=> 2 f001: 4 1
=> 2 f002: 4 1
=> 2 f003: 4 1
=> 2 f004: 4 1
=> 2 f005: 4 1
=> 2 f006: 4 1
=> 2 f007: 4 1
=> 2 f008: 4 1
=> 2 f009: 4 1
=> 2 f00a: 4 4
=> 2 f00b: a 23
=> 2 f00c: 4 8
=> 2 f00d: 4 3
=> 2 f00e: 4 3
=> 2 f00f: a 31
=> 2 f010: a 23
=> 3 10f: 2 9
=> 3 110: 2 4
=> 3 112: 3 1
=> 3 11a: 5 1
=> 3 11b: 5 1
=> 3 128: 3 1
=> 3 131: 2 27
=> 3 132: 2 20
=> 3 213: 3 1
=> 3 8298: 2 5
=> 3 8769: 4 1
=> 0 829a: 5 1
=> 0 829d: 5 1
=> 0 8822: 3 1
=> 0 8827: 3 1
=> 0 8830: 3 1
=> 0 9000: 7 4
=> 0 9003: 2 20
=> 0 9004: 2 20
=> 0 9101: 7 4
=> 0 9102: 5 1
=> 0 9201: a 1
=> 0 9202: 5 1
=> 0 9203: a 1
=> 0 9204: a 1
=> 0 9205: 5 1
=> 0 9207: 3 1
=> 0 9208: 3 1
=> 0 9209: 3 1
=> 0 920a: 5 1
=> 0 927c: 7 870
=> 0 a000: 7 4
=> 0 a001: 3 1
=> 0 a002: 4 1
=> 0 a003: 4 1
=> 0 a005: 4 1
=> 0 40001: 2 4
=> 0 40002: 7 4
=> 0 a20e: 5 1
=> 0 a20f: 5 1
=> 0 a210: 3 1
=> 0 a217: 3 1
=> 0 a300: 7 1
=> 0 a301: 7 1
=> 0 a401: 3 1
=> 0 a402: 3 1
=> 0 a403: 3 1
=> 0 a406: 3 1
=> 0 a40a: 3 1
=> 0 a40c: 3 1
=> 3 c4a5: 7 106
=> 4 103: 3 1
=> 4 112: 3 1
=> 4 11a: 5 1
=> 4 11b: 5 1
=> 4 128: 3 1
=> 4 201: 4 1
=> 4 202: 4 1
=> 4 213: 3 1
LOADED & CREATED
BLOB length 979
LOAD BITMAP </Volumes/T7 Photos/Architecture/Early Spring Market Street.tif>
GFF :: LoadThumbnail : 635 512  (0)
LOADED & CREATED
BLOB length 3298
LOAD BITMAP </Volumes/T7 Photos/Architecture/Garden, Berkeley.JPG>
LOADED & CREATED
BLOB length 1404
LOAD BITMAP </Volumes/T7 Photos/Architecture/Getty Museum LA Sept05 (3).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Getty Museum LA Sept05 (37).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Getty Museum LA Sept05 (38).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Getty Museum LA Sept05 (4).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Green Glass001SF.JPG>
LOADED & CREATED
BLOB length 3297
LOAD BITMAP </Volumes/T7 Photos/Architecture/Green Glass002SF.JPG>
LOADED & CREATED
BLOB length 3297
LOAD BITMAP </Volumes/T7 Photos/Architecture/Green Glass003SF.JPG>
LOADED & CREATED
BLOB length 3297
LOAD BITMAP </Volumes/T7 Photos/Architecture/Help Wanted.JPG>
LOADED & CREATED
BLOB length 1354
LOAD BITMAP </Volumes/T7 Photos/Architecture/Home Colusa Avenue.JPG>
LOADED & CREATED
BLOB length 2795
LOAD BITMAP </Volumes/T7 Photos/Architecture/Home Colusa Avenue.tif>
GFF :: LoadThumbnail : 602 512  (0)
LOADED & CREATED
BLOB length 3406
LOAD BITMAP </Volumes/T7 Photos/Architecture/Hotel Monaco, SF_6171.JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/House - Kensington.JPG>
LOADED & CREATED
BLOB length 1346
LOAD BITMAP </Volumes/T7 Photos/Architecture/house generic fuj astia 1001820_edited-1.jpg>
LOADED & CREATED
BLOB length 1666
LOAD BITMAP </Volumes/T7 Photos/Architecture/IMG_1087.JPG>
LOADED & CREATED
BLOB length 1382
LOAD BITMAP </Volumes/T7 Photos/Architecture/IMG_1246.JPG>
LOADED & CREATED
BLOB length 3297
LOAD BITMAP </Volumes/T7 Photos/Architecture/IMG_5694.jpg>
GFF :: LoadThumbnail : 110 128  (0)
LOADED & CREATED
BLOB length 10000
LOAD BITMAP </Volumes/T7 Photos/Architecture/Interior, Living Room.JPG>
LOADED & CREATED
BLOB length 991
LOAD BITMAP </Volumes/T7 Photos/Architecture/Japanese Style Fence-002_HDR.tif>
         0
LOADED & CREATED
BLOB length 1338
LOAD BITMAP </Volumes/T7 Photos/Architecture/Lorin Hill bathroom NIK.tif>
         0
LOADED & CREATED
BLOB length 3037
LOAD BITMAP </Volumes/T7 Photos/Architecture/Lorin Hill bathroom.JPG>
LOADED & CREATED
BLOB length 2368
LOAD BITMAP </Volumes/T7 Photos/Architecture/Lorin Hill bathroom2.JPG>
LOADED & CREATED
BLOB length 1131
LOAD BITMAP </Volumes/T7 Photos/Architecture/Lucy Arnaz.JPG>
LOADED & CREATED
BLOB length 1615
LOAD BITMAP </Volumes/T7 Photos/Architecture/masonc temple.jpeg>
GFF :: LoadThumbnail : 160 132  (0)
LOADED & CREATED
BLOB length 1018
LOAD BITMAP </Volumes/T7 Photos/Architecture/oakview.jpeg>
GFF :: LoadThumbnail : 160 110  (0)
LOADED & CREATED
BLOB length 490
LOAD BITMAP </Volumes/T7 Photos/Architecture/ochre copy.tif>
LOADED & CREATED
BLOB length 18988
LOAD BITMAP </Volumes/T7 Photos/Architecture/ochre.tif>
LOADED & CREATED
BLOB length 6559
LOAD BITMAP </Volumes/T7 Photos/Architecture/Pauley ••• SPAM ••• - San Mateo.TIF>
         0
GFF :: LoadThumbnail : 520 512  (0)
LOADED & CREATED
BLOB length 10743
LOAD BITMAP </Volumes/T7 Photos/Architecture/Pauley ••• SPAM ••• 2 - San Mateo.TIF>
LOADED & CREATED
BLOB length 11345
LOAD BITMAP </Volumes/T7 Photos/Architecture/Red Teapot Under Curved Roof 2a.tif>
LOADED & CREATED
BLOB length 3438
LOAD BITMAP </Volumes/T7 Photos/Architecture/Red Teapot Under Curved Roof crop2.tif>
GFF :: LoadThumbnail : 446 512  (0)
LOADED & CREATED
BLOB length 3624
LOAD BITMAP </Volumes/T7 Photos/Architecture/Red Teapot Under Curved Roof.tif>
         0
LOADED & CREATED
BLOB length 3564
LOAD BITMAP </Volumes/T7 Photos/Architecture/San Francisco1287.JPG>
LOADED & CREATED
BLOB length 3297
LOAD BITMAP </Volumes/T7 Photos/Architecture/Santa Fe_edited.jpg>
GFF :: LoadThumbnail : 128 96  (0)
LOADED & CREATED
BLOB length 6133
LOAD BITMAP </Volumes/T7 Photos/Architecture/Santa Fe_sandstorm_resized-001.tif>
         0
LOADED & CREATED
BLOB length 3691
LOAD BITMAP </Volumes/T7 Photos/Architecture/Santa Fe_sandstorm_resized.tif>
         0
LOADED & CREATED
BLOB length 3489
LOAD BITMAP </Volumes/T7 Photos/Architecture/Santa Fe_sandstorm.tif>
LOADED & CREATED
BLOB length 3250
LOAD BITMAP </Volumes/T7 Photos/Architecture/Santa Fe.psd>
  JPEG load : 0.150470  638 512
  JPEG load : 256 192
GFF :: LoadThumbnail : 256 192  (0)
LOADED & CREATED
BLOB length 1426
LOAD BITMAP </Volumes/T7 Photos/Architecture/Spanish style house Kensington001.JPG>
LOADED & CREATED
BLOB length 4275
LOAD BITMAP </Volumes/T7 Photos/Architecture/Spanish style house Kensington002.JPG>
LOADED & CREATED
BLOB length 4271
LOAD BITMAP </Volumes/T7 Photos/Architecture/Spanish style house Kensington003.JPG>
LOADED & CREATED
BLOB length 4271
LOAD BITMAP </Volumes/T7 Photos/Architecture/Steeple Richmond CA  600 dpi.jpg>
GFF :: LoadThumbnail : 515 512  (0)
LOADED & CREATED
BLOB length 850
LOAD BITMAP </Volumes/T7 Photos/Architecture/Steeple, Richmond CA.tif>
         0
GFF :: LoadThumbnail : 509 512  (0)
LOADED & CREATED
BLOB length 1773
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence - Rain Kensington001.JPG>
LOADED & CREATED
BLOB length 4269
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence - Rain Kensington002.JPG>
LOADED & CREATED
BLOB length 4268
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence - Rain Kensington002.tif>
GFF :: LoadThumbnail : 632 512  (0)
LOADED & CREATED
BLOB length 19790
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence - Rain Kensington003.JPG>
LOADED & CREATED
BLOB length 4271
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence - Rain Kensington003.tif>
         0
GFF :: LoadThumbnail : 638 429  (0)
LOADED & CREATED
BLOB length 19153
LOAD BITMAP </Volumes/T7 Photos/Architecture/Stone Fence Blue Mullions Kensington001.tif>
GFF :: LoadThumbnail : 612 512  (0)
LOADED & CREATED
BLOB length 20913
LOAD BITMAP </Volumes/T7 Photos/Architecture/Thumbs.db>
GFF :: LoadThumbnail : 0 0  (2)
ThumbLoaderThread - ADD into DB (-1)
BLOB length 75
LOAD BITMAP </Volumes/T7 Photos/Architecture/Trompe l'Oeil.jpg>
GFF :: LoadThumbnail : 160 152  (0)
LOADED & CREATED
BLOB length 2272
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (1).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (10).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (11).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (12).JPG>
LOADED & CREATED
BLOB length 1561
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (13).JPG>
LOADED & CREATED
BLOB length 1561
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (14).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (15).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (16).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (17).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (2).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (22).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (23).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (24).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (25).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (26).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (27).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (28).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (29).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (3).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (30).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (31).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (32).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (4).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (5).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (6)_hnf.jpg>
LOADED & CREATED
BLOB length 1984
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (6).JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (7).JPG>
LOADED & CREATED
BLOB length 9705
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (8).JPG>
LOADED & CREATED
BLOB length 9707
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05 (9).JPG>
LOADED & CREATED
BLOB length 10218
LOAD BITMAP </Volumes/T7 Photos/Architecture/Venice Canals Sept05.JPG>
LOADED & CREATED
BLOB length 1954
LOAD BITMAP </Volumes/T7 Photos/Architecture/View from City Club 2 bw, Berkeley.tif>
LOADED & CREATED
         0
BLOB length 3474
LOAD BITMAP </Volumes/T7 Photos/Architecture/View from City Club 2 crop, Berkeley_edited-1.tif>
GFF :: LoadThumbnail : 638 511  (0)
LOADED & CREATED
BLOB length 3478
LOAD BITMAP </Volumes/T7 Photos/Architecture/View from City Club 2, Berkeley.jpeg>
LOADED & CREATED
BLOB length 3683
LOAD BITMAP </Volumes/T7 Photos/Architecture/View from City Club, Berkeley.tif>
LOADED & CREATED
BLOB length 3160
LOAD BITMAP </Volumes/T7 Photos/Architecture/Waiting Room crop.tif>
GFF :: LoadThumbnail : 638 492  (0)
LOADED & CREATED
BLOB length 1829
LOAD BITMAP </Volumes/T7 Photos/Architecture/Waiting Room.tif>
GFF :: LoadThumbnail : 538 512  (0)
LOADED & CREATED
BLOB length 1221
LOAD BITMAP </Volumes/T7 Photos/Architecture/Washington DC 5203.JPG>
LOADED & CREATED
BLOB length 1954
yes, do you have tried to start PSE in this log?
faro347
Post by faro347 »
HI.
I am able to open PSE in the log. But am unable to open an image into pse after opening the program in the log. Pse 2024 is unresponsive. Pse 2022 opens the "what would you like to do today?" page. Then, when I select "open photo editor", a turning gear appears and stays for about one minute and then disappears. the pse 2022 photo editor does not open. Do you learn anything from this behavior? Thanks.
faro347
Post by faro347 »
I saw this report on Terminal:
The application /Applications/Adobe Photoshop Elements 2024/Adobe Photoshop Elements 2024.app cannot be opened for an unexpected reason, error=Error Domain=NSCocoaErrorDomain Code=260 "The file “Adobe Photoshop Elements 2024.app” couldn’t be opened because there is no such file." UserInfo={NSURL=file:///Applications/Adobe%20Photoshop%20Elements%202024/Adobe%20Photoshop%20Elements%202024.app, NSFilePath=/Applications/Adobe Photoshop Elements 2024/Adobe Photoshop Elements 2024.app, NSUnderlyingError=0x600002ee04b0 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
BTW XnView does open images in Elements for both versions 2022 and 2024 on a mac laptop.
