1.6.2 bugs
spaceship9876
1.6.2 bugs
Post by spaceship9876 »
1. by default xpview mp 1.62 shows .img files (i.e like an .iso dvd image file) in a folder even when i have selected filter by - "images + folders". Your program says .img is used for a format called Vivid Ray Tracer but the .img file on my computer are an .iso type file not a graphical image. You should make it so that only actual graphical images are shown when someone selects "images + folders". i have attached a screenshot showing the recovery.img file. If you want a test file to try this out you can download this: https://dl.twrp.me/noblelte/recovery.img
2. when i go in settings - formats and uncheck the .img file and click ok it doesn't hide the .img files in the folder that the program is in, i have to switch folders or close the program. Yet if i have .img disabled and re-enable it then it shows the .img files in the existing folder immediately, which is inconsistent behaviour.
3. if i do 'settings - view - status bar' and uncheck 'show print size' it still shows inches on the status bar even after i restart the program.
4. if i select filter by - "images + folders" then double click on an image to view it larger then use the scroll wheel or arrow keys on the keyboard it will display videos that are next in alphabetical order even though i have filtered using "images + folders".
i sent this bug report via email too earlier today, i forgot to check if you had a bug reporting forum.
UPDATE: I have found another bug:
If i change the theme to black or dark and then change it back to default the filelist stays black or dark until you restart the program. I have attached a screenshot of this.
