XnView: MP 1.6.2 - 64 bit
OS: Windows 11 64bit
I shutdown windows always in hibernate mode. This first time I had xnView still in background as app open before shutdown. After wake up from hibernate, all (icons,...) are very big and nothing reacts to clicks.
Reason: I use a Notebook 17" with 150% scaling (2560x1600) and a extern monitor 32" with 100% scaling (1920x1080). Extern monitor is my primary monitor. In most cases notebook is closed. To workaround this issue I can:
1. Restart the app (for extern monitor)
2. Move window from monitor to notebook panel. Its now working with clicks. I can now move it back to monitor and its working fine again.
Effect: Program is not usable after wake up in hibernate mode, if you have two different scales for two monitors (notebook + extern monitor)
See description above
1.6.2: [Hibernate mode] Issue with second monitor which have a other scale factor
Katsumi
