Recycle Bin in a write-protected pendrive cannot be deleted.
josedumoretzsohn
Post by josedumoretzsohn »
The XNviewMP's Recycle Bin in an suddenly write-protected pendrive cannot be deleted.
On a pendrive ( which suddently stopped working today, showing the error "This disk is writing-protected. Remove write-protection ), I tried to delete the images in the pendrive's Recycle Bin to see whether I could remove some possible cause of the sudden and unexplained error. However, the images do not delete on XNviewMP Viewer's Recycle Bin, while on the Windows Explorer viewer they are deleted forever, the respective folder reading "This folder is empry". Does this have anything to do with any XNviewMP's characteristics or properties, or differences from Windows Explorer? I even deactivated the use of the Catalog, thinking this could be a possible cause, but to no use. Is there a solution for that problem? Is this a problem at all?
