Thumbnails for .knob files
satyatunes
Post by satyatunes »
Greetings!
I would like to request thumbnail support for .knob extension/files. This extension is used by KnobMan/jKnobMan application. It's a fantastic application to create volume knobs.
https://www.g200kg.com/jp/software/knobman.html
The author provided a shell extension that worked earlier (Windows 7) but it does not work on Windows 10. It would be awesome if XnView can support thumbnail view for knob extension.
Thanks in advance.
Re: Thumbnails for .knob files
please send me a sample file?
satyatunes
Hi Pierre,
Thanks for looking into this. I have attached a zip file with two .knob files and their png counterparts to this reply.
Cheers.
satyatunes
Any update on this please?
