rc1: Thumbnail spacing "0" should be zero for row
marsh
Post by marsh »
Space between thumbnails at zero setting is now zero between vertical columns. It should also be zero between horizontal rows when names are turned off or no labels are used.
XnView 1.82 <x>
Re: rc1: Thumbnail spacing "0" should be zero for
marsh wrote:Space between thumbnails at zero setting is now zero between vertical columns. It should also be zero between horizontal rows when names are turned off or no labels are used.
Currently i have problem problem to have 0 in vertical.
