Hello Pierre,
Thanks for the latest version 1.6.3 of XnViewMP.
Sorry to say, but I have problems to open a directory that contains files/images *.xisf
I downloaded such files (also the attached file) in order to do some metadata-tests with ExifTool.
When I try to open a directory that contains such a file ( e.g. the attached one) XnViewMP crashes.
I hope you can reproduce the error on your system.
Thanks for your help in advance
Best regards
herb
1.6.3 Crash with *.xisf files
herb
Re: 1.6.3 Crash with *.xisf files
please remove xisf.dll from PlugIns folder, and try to install it again with Tools>Plugins'?
herb
Hello Pierre,
thanks for your advice.
I have no crash anymore after downloading the plugin again.
Best regards
herb
Best regards
herb
