I confirm pathname filter is not working, did it work before adding folder name search though? I dont have access to v 1.6.2 to checkmichel038 wrote: Fri Dec 15, 2023 7:24 pm So it seems that the "pathname" I used in the search in the previous first post is perhaps useless...
Folder name search
FKCapitalism2
Folder name search
Re: Folder name search
not working??FKCapitalism2 wrote: Sat Dec 16, 2023 12:23 pmI confirm pathname filter is not working, did it work before adding folder name search though? I dont have access to v 1.6.2 to checkmichel038 wrote: Fri Dec 15, 2023 7:24 pm So it seems that the "pathname" I used in the search in the previous first post is perhaps useless...
not working??
Catalogage avec XnviewMP :
This problem is supposed to be fixed in XnView MP 1.6.4. Please check and confirm the bug fix here.
