Suggest: Aspect pad action could use a pair of integers instead of a rounded decimal ratio
linkakro
Post by linkakro »
I suggest a different method of input for the aspect pad action.
It may and should be an optional alternative mode.
I suggest to input numerator and denominator of the ratio, like we would width and height, in a field each.
Currently v1.99 the ratio is input as a two-decimal-digits decimal number.
I argue that it is too inaccurate.
But changing the length of the mantissa is only shifting the problem to larger pictures especially rational non-decimal ratio such as 2/3.
Three decimal digits would be quite an upgrade for 1000 pixels scale, but i would rather not assume the user only handles small pictures.
I think numerator and denominator fields are more convenient because :
  • Computing the ratio from them is still easy for the program.
  • The program can compute a multiplication then a division instead of expecting a very rounded, quite imperfect ratio from an early division.
  • When it is not already well known, i think it is more convenient for the user to input two integers than computing the ratio themselves.
For example if i input 4/3 or 1280/720, i am not bothered by rounding until the potential most-likely ONE pixel rounding.
Compare with inputting 1.33 or 1.78 on a 2000 pixel image. The rounding becomes about 6 pixels in the updated dimension. Not everyone will neglect it in every case, even if it sounds pedantic to most.
