Batch adding date to photo - just to say : thanks!
mrwul
Post by mrwul »
I regularly want to add date-time to a photo, or screenshot.
When only a few photos/screenshots, I create in Snagit and then add the date-time manually (add a text box, with the date time).
One by one.
Now I had a series of 40 photos, so I went on to search for tools that could do that.
From one site to the other, then I discoved the trick using 'Batch Convert', then Add Action, select EXIF, Date Time taken, etc.
Just to say THANKS to Pierre!
It saves me a lot of time.
(yes .. I should be ashamed: I was not aware of this feature...)
Re: Batch adding date to photo - just to say : thanks!
:D
Post by michel038 »
Since year 20xx, it is no longer possible to add a caption to photos in Google photos.
With batch convert, we can automatically add a banner (canvas resize, height 110%) under the photos and add captions, titles, names, dates, etc. to them.
I also check or change timestamps to make sure that the photos can easily be sorted in the right order in G albums.
Great tutorial, mrwul 8-)
