I often use the batch conversion dialog with different conversion presets (action: resize to longest side, etc.).
In XnviewMP 1.6.2 and older versions the last used action list was saved after closing the batch dialog.
In version 1.6.3 this bevaiour changed. The action list will not be saved, but all other settings (e.g. file format, used cpu cores, etc.).
Is it possible to save the action list, too? - Thank you!
1.6.3 - Batch conversion - action list [solved]
masterjp
Re: 1.6.3 - Batch conversion - action list
'Settings>Save actions list' is enabled?
masterjp
Wonderful! Now it saves the list.
