Export metadata to Excel?
vava_kolev
Post by vava_kolev »
Hello there, I've searched but couldn't find an answer and that's why I'm opening a new topic.
Is there any way to export metadata to Excel from XnView MP?
I understand that it could be done in XnView Classic but there is a problem with the Cyrillics in this software - I'm from Bulgaria and I need to upload some specific info in the images in my own language.
Thank you for the support and have a great year ahead!
Re: Export metadata to Excel?
Post by michel038 »
Select some files or a folder
Then you can use : Create > File list ... menu
Add the required fields
And choose CSV for output format
