Relocate Multiple Paths
st11x
Post by st11x »
I learnt that I could use the relocate path feature should a folder change outside of the application.
In my Catalog dialog, I have these directories all hanging off the same parent.
If H:\Library was moved to D:\Library, do I have to go change each and every one of the paths? Is there a more convenient way to do this?
I opened up the DB file and saw that there is a Folders table with all the paths in it. Can I just bulk "relocate" with a SQL?
Also, what does the Delete option do? Does it remove the selected path and all assets that are tagged with categories?
thanks
Matt
Re: Relocate Multiple Paths
st11x wrote: Mon Jan 01, 2024 9:38 pm I opened up the DB file and saw that there is a Folders table with all the paths in it. Can I just bulk "relocate" with a SQL?
yes you can change paths in Folders table with SQL request
st11x
Post by st11x »
Got it. I suppose when it comes to that, we have to do it via SQL as the UI treat each directory separate even if it's a parent and child.
I selected an entry and clicked on the Delete All to test what it will do, but selected No in the dialog that pops up. It still deleted quite a number of entries (in this case, all of the "C:\*" entries except one. I couldn't figure out the pattern.
My intention was to cancel but I selected "No" by mistake. I made backups so no worries.
thanks
Matt
