Compare images that are not framed equally
FKCapitalism2
Post by FKCapitalism2 »
I have two images one is framed little differently than another yet i want to compare the middle part of it, is there way to freeze one of the compare windows to adjust the opposite image to same position then unfreeze and continue compare so both images are in perfect alignment?
If not could you add this feature?
m.Th.
Re: Compare images that are not framed equally
Post by m.Th. »
Move with the right click.
Zoom with Ctrl pressed.
m. Th.
FKCapitalism2
m.Th. wrote: Fri Jan 05, 2024 2:35 pm Move with the right click.
Nice that works, i was looking for dedicated button at first.
