Categories after change locations
tomasburancgi
Post by tomasburancgi »
Hello, I use XnView as an asset library where I categorize various files. However, I have a dilemma. What happens when the path changes? For example, if everything from disk D is moved to disk E, all files will have a different path. What can I do in such a case? Is there a simple way to automatically assign all files to categories as they were before?
Re: Categories after change locations
if parent path change, the only way is to change the database with SQL request
