XnConvert Version 1.99 - 32 bit/64 bit
OS: Windows 11/64bit
I'm not sure this is really an XnConvert problem but am mentioning it here as it effects XnConvert.
After installing another piece of third-party software called IceDrive - https://icedrive.net/ - XnConvert reports an error saying "The ordinal 380 could not be located" in ShellExtensions.dll pointing to the version in the IceDrive folder (see attachment).
This seems to happen if I drag & drop a file into an open instance of XnConvert. The dialog box appears three times and XnConvert then displays the loaded images and appears to convert them OK. If I open XnConvert by double-clicking on the file instead, no message appears.
As there doesn't actually seem to be a problem, it is odd than an error is reported - let alone that the same error is reported three times.
Error in ShellExtensions.dll
Philsp
Philsp
Re: Error in ShellExtensions.dll
FWIW, IceDrive have identified the problem at their end do it will hopefully be resolved soon.
thanks for the info
