XnViewMP 1.6.4 - Browser Window - Recycle Bin - System settings visible, but without function
masterjp
Post by masterjp »
In XnviewMP I tried to open the red marked entrys in browser window (e.g. recycle bin, system controls, etc.).
All of them are without function. Maybe network works, if you have a network.
I know, it is impossible to use them within Xnviewmp.
Is it possible to remove them or make them invisble?
At least the ones, which does not work?
Re: XnViewMP 1.6.4 - Browser Window - Recycle Bin - System settings visible, but without function
i would like that these entrys works, instead to remove them
masterjp
Post by masterjp »
Okay, then do not remove them. Recycle Bin would be useful.
