Black window title bar when dark theme is active
Lord_D
Post by Lord_D »
Window title bar is white when dark theme is active:
It is posible to make it black
by adding to qt.conf those lines:
[Platforms]
WindowsArguments = darkmode=1
or launching XnView with platform argument:
"C:\Program Files\XnViewMP\xnviewmp.exe" -platform windows:darkmode=1
To achieve this behavior programmatically, Qt Blog suggests to set the environment variable in the main function via
qsetenv("QT_QPA_PLATFORM", "windows:darkmode=1")
DarkDarkEverything
Re: Black window title bar when dark theme is active
Post by DarkDarkEverything »
Lord_D wrote: Fri Jan 12, 2024 5:29 am by adding to qt.conf those lines:
[Platforms]
That worked, thank you very much, would be great if that could be the default.
Oh, no. I just upgraded to the latest version (downloaded the Windows Setup) and the setting was rightout overwritten.
So changing the qt.conf file isn't really an option.
And command line parameters aren't an option either when using XNViewMP as the default image viewer.
So basically the program can do it but doesn't use its own functionality :(
KLE-France
Post by KLE-France »
+1
KLE-France
Beyond the "+1", this excellent suggestion should also extend to the "Black" and "Old dark" themes as well. Bref, the Window's title bar should be harmonized with the color scheme.
currently the only way is to change qt.conf
artguy321
Post by artguy321 »
hi, sorry to bump this, but the white title bar in the dark theme is very distracting. any way to fix this in the program? not all of us are able to follow the workaround. great program except for this minor detail that causes a huge headache.. thanks!
nyahhhhh
Post by nyahhhhh »
heloooo
so i tried the thing on top and it didnt worked.
figured out you could write this on qt.conf:
[Platforms]
 [Qt]
Style = Fusion
this worked for me so i hope it helps ! ^^
