how can I achieve in XnView MP the layout of the browser with the selected image on the right side?
Thx for your help
Layout of browser
Bronimus
Layout of browser
Kind regards / Schönen Gruß vom Bronimus
Windows 11 Home, XnViewMP 1.8.6 64-bit
Franky
Re: Layout of browser
hi,
You can organize your layout as you want by choosing a free layout in View/Layout/Free.
Don't forget to save then to find it if necessary.
Bronimus
Hi Franky,
thx for your answer.
Now I "played" a little bit with the panels and saving the layout.
Now there are (for the moment) two further questions:
- Is it possible to show the "Information" panel together with the preview panel below on the right side of the layout?
- How to delete a saved layout?
Franky
Yes you can organize your layout as you want.
I have not found how to delete a layout from the application, I delete them from the folder
C:\users\***** \AppData\Roaming\XnViewMP\layoutx.dat
Bronimus
Thx for your help
