How to get browser to show svg thumbnails?
Koogle
Post by Koogle »
I just get this..
Re: How to get browser to show svg thumbnails?
in 'Settings>Custom filter', do you have svg in 'Exclude'?
Koogle
Post by Koogle »
yeah that was the issue..
only problem now is.. unlike other image types I can open one from the browser and mousewheel to cycle through other images in that folder...
doesn't work with the .svg ones...? is there another setting for that?
you need to 'update catalog from files' for these svg
gharbeia
Post by gharbeia »
I have the same issue, even though the exclude filter has "htm html mht mhtml xml xhtml eml nws url", but it doesn't work even after having removed all of them.
I'm on Linux. Any dependencies that I should make sure are installed in the system?
XnViewMP 1.8.8 64-bit (Linux) - libformat 7.22.1
even after 'update catalog from files'?
