Slow Start with XnView MP 1.6.4 Windows 11 64-bit
yoshi41
Post by yoshi41 »
I have random (at least I thought it's random) long loading times when opening a picture since a while. If I double-click a picture, it's opened and displayed immediately but it takes about 25 seconds until XnView MP is responsive.
Now I was curious enough to isolate the reason and I found it. Apologies if there's already a thread, I couldn't find it.
As soon as there is a network folder shortcut in the same directory as the picture and the network folder is not available, XnView MP is hanging about 25 seconds. I marked the position in the debug output below.
I my case, I have shortcuts for UNC paths like "\\another_pc\d$" to other PCs on the desktop. If I remove those shortcuts, no delay at all.
Is there a setting to prevent this behaviour?
I just want to open a single picture and at least from a user perspective, I don't want to browse anything else in the picture's directory.
EDIT: Just realized there's a newer version 1.6.4. Updated and behaviour is exactly the same.
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1278 1360
w.init
w.start
libpng warning: iCCP: known incorrect sRGB profile
QObject::connect: No such slot AbstractViewWindow::onPagePrevious()
##PB connect <1onPagePrevious()>
QObject::connect: No such slot AbstractViewWindow::onPageNext()
##PB connect <1onPageNext()>
QObject::connect: No such slot AbstractViewWindow::onPageFirst()
##PB connect <1onPageFirst()>
QObject::connect: No such slot AbstractViewWindow::onPageLast()
##PB connect <1onPageLast()>
QObject::connect: No such slot AbstractViewWindow::onUseSmooth()
##PB connect <1onUseSmooth()>
QObject::connect: No such slot AbstractViewWindow::onNormalize2()
##PB connect <1onNormalize2()>
QObject::connect: No such slot AbstractViewWindow::onAlign()
##PB connect <1onAlign()>
MENU install : 000001F5EB38CE50
Create window finished
==> 1278
ThumbLoaderThread :: stop()
@@ BitmapResizeThread:: clear
MyView::change C:/Users/Yoshi/Desktop/maniac_1_26.jpg
## Bitmap :: load 0
###### GFF:load <C:/Users/Yoshi/Desktop/maniac_1_26.jpg>
####LOAD <C:/Users/Yoshi/Desktop/maniac_1_26.jpg>  0
### resetViewport (000001F5EB3A04B0)  ==> 1278 1258  (1240 1258) 0 0
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
### ThumbLoaderThread :: setFileList(1)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : eb5ded90
######ThumbLoaderThread :: forever : eb5ded90
 ** start condition wait
### ThumbLoaderThread :: setFileList() after wait
 ** start condition wake one 2
setCurrentFilename <C:/Users/Yoshi/Desktop/maniac_1_26.jpg>
######ThumbLoaderThread :: forever 2 : eb5ded90
CHECK <1>
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
### START 1
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
######ThumbLoaderThread :: start : 1     -1 -1
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
### resetViewport (000001F5EB3A04B0)  ==> 2560 1267  (1249 1267) 0 0
### ThumbLoaderThread :: setFileList(0)
CHECK <0>
## OPEN FOLDER
* ROUGHLY 25 SECONDS WAIT TIME *
## Check folder
  ## Check companion  0
  ## Check companion ok  0
  ## OPEN DB FOLDER ok  22434
  ## UPDATE DB FOLDER ok  22434
  ## OPEN FOLDER ok  22434
## updateLabel  22435
## updateLabels ok  22435
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
## OPEN FOLDER done  22446
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
### ThumbLoaderThread :: updateFileList
### ThumbLoaderThread :: updateFileList ok
############### UPDATE MENU ############
### ThumbLoaderThread :: setFileList(2)
CHECK <1>
### START 2
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 1
SORT the list... 1
jayboyjayboy
Re: Slow Start with XnView MP 1.6.4 Windows 11 64-bit
Post by jayboyjayboy »
I have this exact exact same problem.
forgot to say that this issue has always been there for me. it's always why i go back from MP to CLASSIC. it seems if the folder or directory has a network shortcut of any kind, there is about a 8-12 second lag.
jayboyjayboy
have you found any fixes for this?
jayboyjayboy wrote: Thu Feb 22, 2024 1:19 pm have you found any fixes for this?
I have the same problem with Classic, if there is a 'dead' shared folder, it takes 10 sec. Perhaps you don't show them in Classic and show them in MP?
drylightn
Post by drylightn »
Has there been any fix for this? I'm having the same issue, been dealing with it for a while now. But I don't remember it always being this way? I can't really remove the dead network shortcuts because occasionally I have to connect to those network paths for work. (The shortcuts are not always dead, it's just sometimes the server isn't sharing that particular path).
jayboyjayboy
My workaround has been to put the shortcuts (that are presumably slowing the app down) into FOLDERS.
It's not ideal, but it works for me.
