Save the input file list in XnConvert
marcot
Post by marcot »
apologies if this has been asked before, but cannot find any reference to it.
I am trying to find a better way to convert a big number of large files in a single folder using two different settings, based on dimension.
More specifically, large dimensions are to be resized and converted, while not so large instead just converted.
The only way I have found so far is to open the entire folder and remove the files not matching the first criteria, then convert.
Then close the program, reopen it and remove the files not matching the second criteria, then convert.
What I am trying to avoid is the time taken to open the folder the second time, since it can be a long time.
Is there a way to save the input file list after it has been read the first time?
Thanks a lot/Regards
Re: Save the input file list in XnConvert
sorry but currently no way
marcot
Post by marcot »
Thanks.
