Where are the configuration files stored
monmon
Post by monmon »
Where are the configuration files stored?
Alternatively, is there a way to import settings?
bugreporter
Re: Where are the configuration files stored
Post by bugreporter »
Could you please specify your OS?
bugreporter
You can view your configuration file depend upon OS below locations.
On Windows:
C:\Users\<YourUsername>\AppData\Roaming\XnViewMP
On macOS:
/Users/<YourUsername>/Library/Application Support/XnViewMP
On Linux:
/home/<YourUsername>/.config/XnViewMP
monmon
Post by monmon »
I am using Windows 10
monmon
Post by monmon »
Thanks for answering!
