Redundant labels under the sketch
Mrakobes666
Post by Mrakobes666 »
I have configured the display of information in 4 lines in the photo, unfortunately the folders have 4 empty lines - how to solve this?
Re: Redundant labels under the sketch
which labels?
Mrakobes666
I'm sorry, I put it wrong. Captions under the sketch. When there is information that they have content, and in the case of folders, empty lines remain, taking up space. They are visible in the screenshot - blue stripes at the bottom
Many labels can't be filled for folder
Mrakobes666
I understand this with a lot of files. I want these fields not to be displayed as empty lines and not to take up vertical space on the screen. Make a separate menu for file signatures and folder signatures
All thumbnails take same space
Mrakobes666
I can't understand why I can't explain myself. Look - there is a direct dependence on the sketch subscription settings - the more fields for photos, the more the fields for folders increase, but they are empty
yes you have same fields for folder and image, the space for thumbnails is the same
Mrakobes666
Please tell me how to make different ones. I really love your program, I spend a lot of time in it, I want more convenience
Post by michel038 »
The author means that it is not possible to assign different heights to folder and file thumbnails in the browser. He is therefore forced to leave empty spaces below folder thumbnails.
You can reduce the number of fields under file thumbnails, and display this information in tooltips, so that the browser will display more files.
You can also reduce some values in Settings> Thumbnail > Appearance (Shadow, borders, spacing )
Mrakobes666
Thanks for the reply. I thought maybe there was some kind of setup. I will count on the author to take this nuance into account
