Gallery view+Status bar: Disable color depth and aspect ratio in image properties info
tobwz
Post by tobwz »
Assume I open Gallery view for a folder with some images in XnView MP and mark one of the photos.
Then just below the marked photo a lot of information is listed e.g.
dummy.jpg 1400x1050x24, 17.09.2021 09:58
Similarly in the Status bar image properties appear (for the marked photo) e.g.:
dummy.jpg 1400x1050x24 (1.33)
How can I omit color depth and aspect ratio from both types of image information (ONLY (!) trailing part):
.......x24 (1.33)
I only want to see widthxheight
Re: Gallery view+Status bar: Disable color depth and aspect ratio in image properties info
Settings>Browser>Statusbar
tobwz
Post by tobwz »
If you look on
then there is NO separate checkbox for
width x height
and
users can enable all image properties or none.
So I ask again:
Is it possible to add a "show width x height only" checkbox at the mentioned dialog?
