XMP field not the same as Exiftool
ericesquivel
Post by ericesquivel »
XnView: MP 1.6.4 - 64-bit
OS: Windows 10 - 64-bit
Some values with XMP-DC with multiple languages are not displayed correctly in the XMP tab.
Same value is display in all languages
In the EXIFTOOL tab it is correct.
Or add metadata with exiftool on whatever image.
exiftool -XMP-dc:title-x-default=test default language" -XMP-dc:title-fr="test FR" test.jpg
2. See Info panel from Xnview compare to Exiftool panel. Exiftoolpanel is correct
Expected behaviour:
Different value in XMP dc titles for each language.
Re: XMP field not the same as Exiftool
right, perhaps a problem with Adobe XMP SDK, i need to check if it's a known issue
